Can't get lockdown bar secure on Addams
hackbar
California
I'm trying to get the lockdown bar tight on an Addams Family. When the level is locked, the bar is still loose.
The level goes almost all the way to the right (it goes about 1/2" less with the bar than without). I've played with the adjusting screws, and they don't seem to matter. Even at almost all the way out, there's not difference.
Is there a trick to this?
You could be tightening the wrong way, are you going clockwise or anti clockwise. Try the other way. Pretty sure the screws go down to tighten, up to loosen.
Also how does the felt look on the underside of the bar. May be so squished it might be worth replacing.
