Hi,
I'm wondering if someone has seen this problem before and can lend some advice. Just got a High Speed machine and I can't seem to access the system diagnosics. Well I shouldn't say I can't, but when I open the coin door and hit the advance button the machine jumps right to the "music test". As far as I can tell from the manual this would mean the auto up / manual down button is in the down position, but this test comes up no matter which position I have that button in. I can't get any further past the music test no matter what buttons I hit. The only way for me to make the music stop is to turn the machine off. I've checked the wires back all the way back to 1J14 on the CPU and reseated the connectors but still no luck. I've also checked and the coin door is grounded as well. I'm hoping that this is just a problem with the 3 button switch, but I'm not sure. At start up I was getting an adj switch 37 error, but I replaced the left eos switch and that error is no longer coming up. Any advice would be appreciated. Thanks. mike
