Hi Chad
I have a cyberlead cabinet that has a Eizo tube and (I believe) a Toei 15/24 chassis. 2 questions for you if you dont mind.
Firstly, Does the chassis have a pin cushion adjustment? This cab is hard to get in to inspect the chassis so I figured you might have the answer before I started dis-assembling it.
Secondly, I am having some vertical fold over at the top inch of the display. I believe this can be fixed my replacing a cap on the neck card but I havent the slightest idea which. Is this correct that this would fix it and do you happen to know and/or have the correct cap that I would need? If you happen to have a full cap list and maybe even have them for sale that would be excellent too!
Thanks for any advice and sorry for hijacking your thread Raven.
