I'm assuming you mean entire monitors and not just chassis, right?
Yes. As long as they are both of the same resolution and the frames are the same, they should swap easily. Sometimes you'll find the power connectors are different (depending on which cab they were in previously) and you'll have to change one (just swap the housings, too), but the video connector should be the same. The only thing you might have to change is removal of a negative vertical sync wire if the game uses composite negative sync and it was jumpered for the 4900 (probably not but you never know) as the 7000 won't sync with it jumpered...
