Can the boards interchange between Pac Man cabs?
Cibernetico
Yonkers, New York
Just wanted to know since I can't find another Ms Pac Man cab that has an owner that actually bothers to answer their emails :)
I do notice that there are some regular Pac Man cabs around and I will try to contact these owners. However, do the boards interchange?
Thanks for the answer.
got an extra question. Should I expect to pay more for a Pac Man cab compared to a Ms Pac Man?
you should not play more for a similar condition Pacman as you would a Ms. Pacman, possibly even less as the latter seems to be the more popular of the two.
you can also swap in a JR Pac board if it's from a conversion kit.
mc300baud speaks the truth. Pac Man cabs are definitely more rare, you'll find about 10 Ms Pacs for every Pac you find, but Ms Pacs are in much greater demand and command higher prices despite their lack of rarity. Supply and demand and all that.
If its a midway board a mspac is nothing but a pac pcb with rom changes and a daughterboard.
JrPac PCB came in two flavors, AC and DC version. The AC version is a direct swap into a pac or mspac cab and can be identified by the heatsink on the top left. DC board will not have this heatsink.
Mspac cabs typically cost more than a pac cab because they are more desirable. Although the mspacs were made in much larger numbers I find they are harder to come by than the pacs.
If you need a PCB pm me, I have plenty.
