Can someone with a Freddy pinball chime in
jacobzking
frisco, Texas
I got my circuit boards repaired after my mishap last week... but I have a quick question...
one the controller board (A1... the bottom right board behind the glass) there is a connector (I think labeled P6) that has nothing to plug in to it. It is the most bottom right connector on the board.
Can someone with a Freddy pinball tell me if there's is plugged in? I'm looking at the manual and it appears that it should remain unplugged, just want to be sure. Thanks!
PS: i included a crappy photo, but the connector is kind of hidden behind the ribbon cable... but you can see where it is. thanks!
PPS: Also, how do I remove the glove flipper to repair it. I've seen the "How To's" on how to repair, just not sure how to remove. Thanks again in advance!!!
P6 has no connection.
The glove flipper removes the same as a regular flipper shaft. Lift the playfied and it should be 2 set screws in the flipper pawl and the glove will lift straight out.
