My newly acquired Centipede particle board is swollen on the left and right side of the control panels. I've removed those and will be routing new ones. The width of the gap where they go is right at 25/32nds of an inch. It appears that they have vinyl on each side while the main parts of the cabinet have laminate. Most of all the particle boards are about the same 25/32 +- 1/32" while that may not seem like a big deal, a 32nd can be the difference between a snug fit and a loose fit. Can some check the thickness of this piece please. Thanks.
