pretty hard to price. If somone actually wanted it/had a use for it, you probably could get $400-$500. But I don't think finding a buyer would be easy. So next best use is part it out. What you can get out it:
1:19" wells 7302 monitor. Mine had zero burn. So based on how hard it is to find a nice monitor, I would say its worth $150-$200
2: sega stv pcb. The stv pcb would not boot up USA carts, so it either needs a different bios or it needs the terminator pcb (print club has a plug in top board that has svideo in and out) Might be good to replace a bad stv pcb. If it worked with japanese stv carts, then it might be worth something.
3: print club cart. If you have a cart other than the standard one, it would be worth something. I have a pokemon one, so who knows on that..
4: color camera. Might be useful for a video survelance system.
5: dye sub sony printer.. No idea what it would be worth or if it would have any value today. But if you repurpose it to print photos, it might be useful to someone
6: isolation transformer. looks like its can handle any input or output you could want.
7: dollar bill validator. Works with $1. I don't know if it can be updated to newer currency.
8: high security locks. 3 common locks and 2 unique ones. Good luck breaking into those.. Even drilling one out was not easy..
9: misc parts. Sanwa joystick, very nice florecent light fixtures, some 100v fans, a ton of wiring..
10: Not sure how much 100 lbs of scrap metal is worth.
So I think parted out, you could get $200 - $300..
