jonathan1138
Can someone help me on a simple schematic question?
I have a Tron with a WG42 monitor, which *i think* is equivalent to the WG4900 series.
Game plays blind, but get neck glow. Can be anything at this point. First plan of action is to check all solder joints, as some were suspect when i capped the monitor.
One area that needs attention - C702 when i capped, a trace lifted up immediately upon applying solder - this was a concern. I pushed it down / soldered on the leg of the cap (to the bottom of course). I followed up by checking continuity to other points by following the trace. Unfortunately, i couldnt tell what should have continuity and what shouldnt - i dont want to guess.
So from the manual - page 14 - is it safe to say that anything having a line drawn to C702 should have continuity to it (i should get a buzz?).
Again i want to make sure the trace is back in / doing its job.
http://arcarc.xmission.com/PDF_Monitors/Wells Gardner 19k4901 19k4906 19k4951 19k4956.pdf
