Can someone help? 193- in 1 Happy Fish ver.1
JimFly
Anchorage, Alaska
I have a big problem with the 193 - 1 Multicade.
The color's are dark shaded and has fuzzy horizontal snow lines, but i can see the game' is this by chance a PAL version? or my 25 inch monitor?
Im using a upright original CAPCOM street fighter zero 2 arcade, that works with all my jamma games.
At first i thought it was my blue jamma hardness because it did not fit securely in, so i shaved the sides a little for it to fit perfectly but still the same problem.
If burning it really isn't an option since that's what multigame bootlegs deserve, you'll probably find it doesn't have a video ground pin, and your cab loom doesn't hook video ground to common ground.
Disconnect the PCB, get a meter, measure resistance from pins 1+2 topside to pin 14 topside. If there's no link there's your problem. If there is a link, either your monitor hates it, or it's faulty - see burning option.
