Can someone confirm composite sync wire color for Missile Command edge connector?
nagamitsu
Cambridge, ON, Canada
This Missile Command I picked up, no one was able to figure out why some chips on the PCB kept blowing up. I found that someone appears to have put the composite sync into pin "Z" and then tapped in the negative/ground to controls into the same. What I have confirmed, is a green/white wire that is now in pin "Z" that when tested, goes to molex connector into monitor. Then there is a black wire, that was spliced in, that I have tested goes back to the CP start/control buttons. If I get this back to how it should, replace the blown chips on PCB, then this baby is up and running!
Tim
GND | A | 1 | + 5 return from regulator
+ 5 V Reg. | B | 2 | + 5 V Reg.
| C | 3 |
| D | 4 |
Audio 1 Out | E | 5 | Audio 2 Out
Video Horiz. Sync | F | 6 | Video Vert. Sync
Start 2 LED * | H | 7 | Left Fire Button
Center Fire Button | J | 8 | Right Fire Button
Right Coin Slot * | K | 9 | Left Coin Slot *
Video Blue | L | 10| Video Red
Video Green | M | 11| Left Coin Counter
Center Coin Counter | N | 12| Right Coin Counter
Start 1 LED * | P | 13| Start Button 1 *
Test Switch | R | 14| Slam Switch
Center Coin Slot * | S | 15| Start Button 2 *
Vert. Tball Dir. | T | 16| Vert. Tball Clock
Horiz. Tball Clock | U | 17| Horiz. Tball Dir.
| V | 18| Comp Sync *
| W | 19| - 5 V
| X | 20| + 12 V
+ 5 to Controls | Y | 21| + Sense
GND to Controls | Z | 22| - Sense
Thanks, so it seems green/white should be spliced with black in "Z", green/white is ground from monitor connector. Composite sync is a violet/white going to #18 in edge connector (but isn't on mine).
Tim
