Can someone check this repair job plz
GoneMad
Cavendish, Prince Edward Island, Canada
It's the first time I ever tackled a broken neckboard, but gave it a shot. Can some of the gurus please check this before I fire it up. Thanks.
Hopefully the neck was also glued.. Just make sure all the pads are soldered correctly.. Also, put the cardboard neck cover back on, or make a new one if it's missing.. Fire up and test.
Looks okay. I'd trim the ends of the jumpers back a bit, some of them look uncomfortably close to each other.
yea trim them jumpers up and fire that bad boy up and see.
you can always glue it after the test.
Peace
Buffett
trim the ends of those wires back some, reflow the solder joints like at h10 and any others that look sketchy fire it up and see!! If its good hit it with some clear silicone to stabilize it and put the cardboard back on if you still have it.
I prefer silicone because if i ever need to RE-repair it i can peel that off. Cant peel off epoxy of glue quite as easily lol
