The only problem you may have is if either of your 4900's are meant for the early-version yoke, and the other is meant for the later-version yoke. Look on the back for the silk-screened number. If it ends in -023, it is an early version. If it ends in any other number (like -033, -040, -051 etc) then it is a later version. As long as they are both the same version, you can swap them (except for the 4915 which is medium-resolution).
If you swap different versions, you'll get a foldover issue that won't adjust out, even though the chassis works fine...
