Can I use this PCB in a DK or DK jr cabinet?
alejandromad
Las Vegas, Nevada
I think it's a DK jr clone... maybe "Junior King"?
Has anyone seen this type of PCB or know if it can be used in a standard Nintendo cabinet?
Thanks!
If it did NOT have 'inverted video'... and I plugged it into a Nintendo cab with a 20EZ... would it break anything (PCB, monitor, etc) or simply look crappy?
It'll just look inverted, possibly upside down too. If you have an inverter board on the monitor, easy fix for the color inversion. If it's upside down, time to cut and flip the yoke connector as well.
you may want to disconnect the small white connector from your sound amp when you test it, or at least turn the volume all the way down.
the board may have amplified sound, and if you run it through your monitors sound amp, may blow your speaker or amp.
QUOTE]
Is a DKJr bootleg set. Generally, they play the Japanese version, and have a sound amplifier on board, and do not need video inversion.
The trick is:
A) do you have a way to correct the video
(You may be lucky if your Sanyo has an installed video inverter board)
B) do you have a harness it will plug into
DK3 had the correct harness and so does a DKJr cocktail table game.
DK, DKJr and Radarscope uprights used the little individual connectors, so this board wouldn't plug in.
I don't know if the monitor in question has such a thing... but I have one... I think. Does the picture attached look like a video inverter board?
B) do you have a harness it will plug into DK3 had the correct harness and so does a DKJr cocktail table game.
There is a local acquaintance that has a DK3 cabinet so I should be good to go there.
Thanks for all the information!
