ScumBum
Can I test a Galaxian board in a MsPac cab ?
The issue I'm having is with the controls , when I press to the right with the joystick , it doesn't always work , I don't know if its the joystick switch , bad connection in the harness to the board , or the Galaxian board itself . I figure if I test the Galaxian board in the MsPac cab , and moving to the right has no problems , I can pin point if its a board issue .
