Can I swap these tubes?
Blades
Nebraska
Can I swap these two tubes?
I have a Zenith G-A63ADG25x 04Rco10-009
and it's Green gun is shot, even with a rejuv....
I have a RCA A63ADT15X05 that came out of a KI 2 cab with missing everything but the tube.
Both tubes were standard Rez. I can't seem to find a data base. Or I suck as searching. But I would take the yoke and rings, chassis etc... off the old Zenith and apply the board and all the krap back onto this RCA. I just want to make sure they are compatible before I go to all the trouble. All pinout are the same and the chassis from the zenith is a WG 7193 if that matters any......Any info would be appreciated! Thanks!!!
Cool, thanks.... I just wanted to make sure that it would work before I went to all the trouble of swapping out the tubes. And also thanks for the link as I will be bookmarking that site for sure. Thanks again! now the fun begins. :cool:
In case anybody is wondering, the rca tube in question was used on Neotec 2515c and Hantarex POLO. Thanks to you guys I am able to save a couple tubes without puzzling over either one of these chassis.
