augusthansen
Can i swap a monitor chassis/tube from asteroids to space invaders deluxe??
So I took the B&W WG V2000 out of my asteroids and it appears as though it will work in my SID. SID had a kv700a/M5000 chassis, asteroids is a WG v2000 chassis, but the tube is the same so i figure it will work, right? Is there anything different I should be weary of with the connector? Will the wiring already be correct?
There are more male pins in the v2000 bulk connector than are accepting in the female end of the SID harness. Is this an issue?
