Can I safety test a JAMMA PCB in my Golden Tee 2004 cab?
If it is a RED Golden Tee board then NO, those use a ATX power supply and not powered through the JAMMA Harness.
If it is a Green board then sure.... as long as your JAMMA board you need to test does not require -5 volts.
So "maybe" is the best I can offer. Because I have no clue what your wanting to test or what you have for hardware...
