Can I put a WG K7000 in a hantarex 25"
ctozzi
Donor 2012
Henderson, Nevada
Excuse my ignorance on monitor stuff, but i'm trying my best to learn as much as i can.
Anyways a quick question, I have 2 Hantarex 25" polo monitors that are missing chassis. So i'm wondering if I can simply add a WG 25" std res chassis to get these up and running ?
Thanks in Advance
Chris
if the yoke value is the same and the pin out of the tube is the same then go for it.
but as far as i know the yokes are not compatible.
don't know about the tubes.
so the short answer is NO.
as i have never heard of it being done as a direct swap.
Peace
Buffett
I'm using a WG U5000 25" chassis but only for CGA 15khz standard resolution mode (dedicated KI2 machine).
The horizontal won't fit the entire tube screen even with the pots adjusted to max, a B+ increase will be necessary.
There's a article on retroblast about using a 8Liners chassis but i'm not sure what model it is:
http://retroblast.arcadecontrols.com/articles/8-Liners_1.html
