Can Dogosoken (jap) be convert to Victory Road (eng)? YES IT CAN.
AncientGames
Donor 2023, 2025
Ontario, Canada
Hi all.
I have 2 of the Japanese versions of Ikari Warriors 2 Victory Road known as Dogosoken.
Is there a way to make the s peach and opening title screen English? Is it as simple as changing the roms to Victory Road roms?
Cheers. MIKE
Dogou Souken to Victory Road
Should be a straight swap out. This works when applied to MAME. The quick way is only four eproms to change out.
P1 and P7 for Title Screen change.
P4 and P5 for English Speech.
  • Dogou Souken to Victory Road.zip
Nearest you, would be Hobby Roms. Provide him with the files above.
I did exactly what you said and gave the files to a buddy with a burner. He did the 4 chips. I just tested it and it worked! English speech and text. Thank you!!!
Always good to know it works on actual hardware. You're most welcome, enjoy!
So slight issue. Rom 4 seems to control some xharacter speech and the enemy sounds. There's an annoying "arf arf" sound coming from the enemies. So I put the old sound rom 4 back in.
