acblunden2
I'm liking what I am seeing!
Uniformity of height and squareness of the bends is the most important thing. Has to be uniform/square along the entire bend and on both sides. Won't work if it isn't. Can't have any height difference on either side anywhere along the bend.
The smaller screw posts will allow for some centering of the joystick base and other joysticks to use this. So I am less concerned about precision of the hole and perfect tolerance for the mounting of the screw posts.
If you have an iL Eurostick handy, fasten the base down good to it and see how the fit is. Bolt it down tight and see if the screw posts stay fastened to the mount. Those screws are going to have to take a lot of force over time so make sure they are in there good. Take some pics. Thanks!
