Does anyone recognize this chassis or can tell me where the part number might be? I can only find a serial number. From my searches it is probably a Nanao MS7-?? but I want to confirm before I try to find a cap kit.
If I had seen this thread earlier I could have immediately told you the model number.
I have this same chassis in my Pac-Man. Nice compact and tidy little chassis that produces a gorgeous picture when rebuilt.
The only thing you need to keep an eye on is pinholes that develop on the flyback that causing arching. However, that's easily fixed with some epoxy.
Thanks! Hadn't heard about pinholes before. Are they visible before arcing? Or do you need to patch them after the fact?
Below is a pic of my PP Matsushita monitor that recently erupted. Does that look like the result of a pin hole that might be patched? I can take a better pic if necessary.
Yes, that appears to be the classic pinhole.
