can any one tell me may a new flat screen style tv be used to make a 60 in 1
kuglerarcade
medina, Ohio
i tryed settting to pc and only get half a image i also took vertcial the and then horz 100 % both ways no help with no luck. thanks
Did you set the PCB's dip switches from CGA to VGA?
Not sure what the resolution is on the PCB, but maybe it is too low for newer LCD TV's??
Might have to use a standard PC LCD monitor.
now are you saying you are using a flat screen tv, or a flat screen computer monitor?
I have used lcd flat screen monitors several times. It make the wiring easy since you just have to plug the wire straight into the pcb.
dip switchs ar set correct.and yes it is a flat screen tv. it has hook up like to use as a mnoitor for your pc
Do you have documentation on the TV? Can it handle a VGA signal instead of an SVGA? That board outputs VGA but computers moved away from VGA nearly 20 years ago and the TV may be expecting a higher resolution.
