Can a monitor be beyond degausing?
Thanks for the reply @brokentoken
I have moved the machine to a different spot, I adjusted the yoke and the rings.
I even re-taped the degauss coli that go's around the tube. the chassis has been recapped.
When I moved the machine next to a power strip thats when it all went bad. since then I have it in a new spot with no interference.
you're a winner.
also I find it immense cringe when I read posts I made in threads 10+ years ago. LOL
Wait? What? So half the people here bitch when someone creates a new thread screaming "USE THE SEARCH FEATURE!!!!!!", then when someone does and they "Necro Bump" it with the same issue the other half screams "CREATE A NEW THREAD!!!"?
WTF people...
i think it is fine to necro bump shit if the original thread wasn't solved. you should also put the solution in both threads if there is more than one.
