modessitt
Can a Matsushita work with a game that has separate sync?
I have a Matsushita here that I pulled from a Millipede for repair (Millipede is still on location). I seem to have it running, but can't get it to sync. From what I can tell from the manual, it requires negative composite sync on pin 5. I am trying to test this with an Arch Rivals cab I have here. The Arch Rivals appears to have separate negative vertical and horizontal sync. The Arch Rivals monitor (K7000) works fine with that sync connected, but I cannot get the Matsushita to sync. Am I going to have to connect this to a cab that uses composite negative sync (like JAMMA) to test it properly? I have tried just connecting the horizontal, as well as tying the horizontal and vertical together, but neither help...
