can a k4600/G07 be used in a frogger cocktail
Patnukem
Nebraska
I found a local working 19 inch monitor from a pagan machine not sure what kind it is I assume a k4600 or a G07. The one in there is not doing so hot even with a new cap kit I suspect it needs a new flyback.
I had originally replaced mine with a 19" POLO monitor. I had to use the mounting harware off the old monitor for it to fit. I also had to mount the chassis against the side of the cab. I've since been able to repair the original monitor and put it back in.
What is happening with the current monitor? Is it the ms2000-s?
it's has a sega mc2030s with an afterburner burn in I think and I could tell it was patched in to there. I believe it has a bad flyback since I replaced all the caps in it. what happens is it will get bright and not focus all the way or dim and focused. I moved it over to my Thunder blade upright I picked up for 35 bucks that had a k7000 that I got a new HOT, flyback and caps for just to find out the voltage regulator was shot too. So I will most likely put that back in when it is fixed and get rid of the few patch wires I made to make the monitor work.
Anyway I was mostly wondering if the 100v power would work with the pacman monitor.
EDIT: realizing the stupidity of that question, I can easily hook it up to the 120v I guess I was out of it when I posted this.
