Can a 464 connect to an external amplifier
mcandrewsoun
Fincastle, Virginia
Thinking of getting a Rockola 464. Is there an easy way to connect the line level audio output of the jukebox to an external stereo system?
Thanks,
Andrew
In the back of the 464 (assuming it's like the 454), there is a connector board. You can hook up speakers to there and you'll be set to go.
Ok, but thats speaker level, not line level..I realize that could be stepped down, but I wondered if there was an RCA or line level available on the PCBs.
You could easily use what's called a "direct box" to interface the speaker level from the speaker terminals on the jukebox to drop the level to line level or mic level to feed another amplifier.
http://www.mcmelectronics.com/product/APPLIED-RESEARCH-TECHNOLOGY-DUALZ-DIRECT-/555-15370
Also suggest joining this group and posting your message there:
http://lists.netlojix.com/pipermail/jukebox-list/2012-March/subject.html
They have some Rockola juke guys there who could answer your questions. It's possible that Rockola may have made an amplifier accessory kit for patching the jukebox to other amplifiers.
