WannaTheater
I picked up a DKJR a few weeks ago where the prior owner tried to do a cap kit and flyback replacement. After cleaning up some bad work, re-running some traces where pads lifted, verifying continuity with meter, etc, I fired it up. Dead. It smelled like plastic heating up, so I shut it down. Found the HOT had the yellow and black wires switched. After I corrected this (HOT still seemed to test good out of circuit with meter), R473 lit up orange. I found a TINY barely visible solder bridge between C302 to the C453.
I then couldn't get B+ to 108VDC... it was either below 90VDC or about 115VDC. The metal pot was very flaky.
Today I replaced the following:
C302 (tested good with meter)
C453 (tested good with meter)
D454
R473
T901 (which tested good out of circuit)
IC601
Now I've adjusted B+ to a solid 108VDC. I have 16DVC at J7. I have neck glow. But I have nothing on the screen. When I switch the "Test" pot, I still get nothing. I can crank up brightness and subbrightness, but get nothing. When I crank up SCREEN all the way, B+ jumps to 136VDC+... I assume that it is going into HV shutdown.
The only time anything comes on the screen is when I switch the power off- A brief flash of colors comes on the middle of the screen.
The monitor also has an separate video input board that mounts on the cage that covers the flyback. I have another cable going from NON INVERT OUT, to the chassis main board. I hope that is correct! (it is also odd that this board has a power header, with only one wire connected... is this normal?)
I am running this without the audio board connected, which has its own set of issues I am working on.
Any advice on where to go from here?
(I am now wondering if the flyback got damaged with the HOT reversed, or the short pulling current across R473, but I have virtually no experience with monitors...)
Thank you!
D454
R473
IC601
Thank you!
