m_mcgovern
I've filtered through many previous posts, but I am hoping that my questions can elicit some more tutorial like suggestions to fix my convergence issue. I am putting together a 25" "amplifone" vector monitor to go into my Star Wars cockpit de-conversion. Like others have done previously, I am using a 100deg 25" medium resolution tube (ID# A63ADG25X), wells gardner 6100 yoke, and amplifone deflection/high voltage pcbs. Here is a zoomed out pic of what I've been able to accomplish (the fading on the right hand side is an artifact of the camera pic...color looks uniform in person):
As you can see all three colors are pretty well converged left/right/up/down in the center (although you can see the green starting to diverge towards the bottom in this center close up pic):
I have the red/blue pretty well converged everywhere. However, I cannot get the green to lay on top of the red/blue near the top and bottom edges. In addition to a small vertical offset, the green does not bow inward to the screen's center as much as the red/blue does:
The sides are fairly well converged, though (certainly better than the top/bottom):
OK. So here are the questions. What can I do to get the green to lay on top of the red/blue on the top and bottom edges? I cannot seem to get there by adjusting the convergence rings. And, further yoke movement left/right/up/down from where I am seems to undo the work to get the red/blue to pretty much align well everywhere. I've also tried moving the rings forward/backward relative to the yoke and re-adjusting them, but I can't get that to do the trick either.
At this point, am I just down to working with the strips and chevron magnets (I have a good supply of both)? If so, are there any tutorials or step-by-step instructions for *how* to use these to achieve convergence on the top and bottom? So far, my experiments where I am just moving them around never gets all three colors to align (most of the time it looks like I am undoing what I have). And, both the strips and chevron magnets seem to have more impact on the corners than the center of the edges, which is where my biggest convergence issue is. Now, I am only fiddling with one strip at a time...perhaps their effect is non linear and using more than one in close proximity will have a greater impact?
Any help or suggestings are greatly appreciated! I want to get this monitor converged and placed back into the cabinet so I can play Star Wars again.
Thanks in advance
Thanks in advance
