California Speed questions
Robomayhem
Leetonia, Ohio
I picked up a California Speed that somebody tried to convert to Crusin' Exotica. The wiring harness has a bunch of re-routed wires and such.
So I was hoping that someone here who has a proper California Speed could kindly take a pic of the PCB boards and connectors all hooked up as it supposed to be and post it here so I can compare it with the abomination that I have aquired.
attachment.php
THANX!
That doesn't look too bad. Looks like a few connectors need to be reconnected to the PCBs. I can take a few pics tomorrow if I don't have them already somewhere.
Cool man, I appreciate it. I do know I am missing the connector to power the HD, and a ribbon cable that goes from the driver board to the main PCB. And a couple of the connectors are the wrong size and don't fit the pins on the PCB.
Pics........
Thanx for the pics MrSinister. It has become aware that I have a half of a C. Speed harness and half of another..
It is amazing how some people do things.
Yeah it doesnt look all that bad. You'll need a manual for wiring schematic and start one by one tracing them. Tedious but probably only way. It seems complete though
Yea, I'd like to find a schematic
The driver board seems to mostly have the correct connectors. But at P7, the 2 brown wires, according to the manual, should be going to the coin meters 1 and 2. But in this case, the brown wires go to the steering motor via a connector :confused:
attachment.php
The subwoofer board seems to have one proper connector, the AC in connector. But the other 2 connectors are MIA.
attachment.php
It seems that the previous guy tried to integrate a Midway harness.
attachment.php
attachment.php
At the end of the day, I have 4 connectors similar to this one that have no where to go on this C. Speed board set. I'll bet they fit an Exotica board set though :rolleyes:
attachment.php
So I would guess that California Speed and Crusin' Exotica share some components. Or maybe they don't, and that is why the guy gave up on it.
Either way I am going to need a new harness, at the very least. Looks like I may have found one too thanx to you Klovians.
