bizvisor
Hi. Newbie here but am loving the wealth of info on the site. I picked up an atari california speed several months ago to add to my personal basement gameroom. Machine is in excellent condition and always for home use with only three previous owners. It has been working fine the past couple months but currently started having a monitor issue. Upon turning on the power switch, the unit fires up and runs through the calibrations and pedal tests. You can play for a few minutes (5-15min) and then the screen goes dark almost like a night time scence. You can barely see the screen and the machine still plays. I have also noticed faint red lines going horizontal. The monitor is a Mitsubishi and the numbers on the tag are A63LCC11X. Any help is greatly appreciated.
Also, shouldthis machine run thru the calibration and tests every time I turn it on? Is it a simple fix of replacing the battery?
Thanks.
Thanks.
