California Speed Manual Shifting
ToplessZ
Donor 11 years: 2011, 2013-2022
Claremore, Oklahoma
I have a California speed that Im trying to change the game to allow me to manual shift on. I updated the harddrive to 2.1a, and I select manual shift but it still does the shifting for me? Anyone had this issue?
Its wired incorrect....i posted in a thread awhile back how to fix. Off top my head reverse the wiring on the shifter. All closed except for the switch selected i believe. Its opposite of cruisn shifters.
hmm having trouble finding the post.
I can go into the test menu and test the switches and when I put it in first gear it registers first, etc.. wouldnt that mean its wired correctly?
ok , just to verify before I head to to my machine (not at my house).
When I put the shifter in 1stgear the 2nd,3rd,and 4th should register in the test menu not 1st gear?
I think what he means is to wire all 4 buttons on the shifter to all be closed (NC) and then when each gear is selected it will open that particular switch.
yea I spoke to Chris last night about it, so Ill have an update hopefully later today.
Awesome!!! Fixed mine too, so if anyone has a cal speed that changes to automatic when you select a manual transmission swapping the wires on all 4 shift switches will fix it.
