After Actually building one from these plans some amendments were made.
Pics have been
updated and listed in RED
On the Main cut list plan there was red writing on it already so the changes are
underlined in red instead
Go for it.
POINTS OF NOTE
1. The monitor is 21", and this detail is left out as each monitor is different
2. We used a panel the same size as the base panel for the monitor, with the screen cut out of it
3. 19mm pine and melamine glue was used with an air operated staple gun (30mm Staples) inside on each corner. But 30mm screws and 19mm square pine corners were tried on the 2nd one, with success - if staples & gun aren't available
4. The monitor actually sits on the 19mm pine corners
5. Iron on black edging was used on bare ends to hide it.
6. Wheels were used and 2 fixed 60mm legs (from bunnings), instead of the levellers.
7. The top size was changed to 560 x 815 so the glazier doesn't get confused
8. The top with glass attached, hinges up, and the monitor stays in the cab
Pics (Click to enlarge)
