mecha
I mean if it's making the problem worse, wouldn't you just remove it from the equation?He can, but that doesn't necessarily explain why he had problems in his cab.
This is a good example of why you want to root cause problems, and not just shotgun something 'until it works', and then make up some story about why it broke (which will eventually spread to other people, creating misinformation).
There's a root cause of why there were problems in this cab. I want to know exactly what it is, down to something I can measure.
we have mostly G05s in the vectors at work, but that Omega Race I've told you about has V2000. since going back to 3716/3792s it seems to be holding up now. could the 3886/3884s it had have been the reason it just somehow bypassed the fast blow deflection fuses and went to wiping the line fuse out? cause that seriously makes zero sense to me.
