melchman
So Battlezone is nearly complete. I am stumped by a right reverse problem though. We have two boardsets, both recently repaired. Set A runs the games fine except the Right tread controller does not go in reverse. When in test mode, the switch test indicated it is not firing. We opened it up and replaced the wiring that was chewed by the last repairer who put the screw through the wire bundle.
We tested the switch for continuity: good
We tested to the CP Harness: Good
We test to the PCB Harness: Good
Connected and Test Mode: FAIL
Set B has a K1 Problem (see Attached). If I move Set A's K1 to Set B then Set B boots and has the same failure on Right Reverse. Tested continuity on the interboard connector, all good.
How do I get the board to "see" Right Reverse?
