The worst Bally MotorDome that boots up to attract.
The cabinet has moisture damage with the head barely holding together. There is no backglass. There is no top glass. There is no lockdown bar.
There are legs. The playfield looks complete. The ramps are melted in places.
The Ni-cad battery has been cut off the MPU board and a temporary battery attached to permit the machine to boot up. The temporary battery is NOT included as it only attached by test clip wiring. This era of Bally requires battery to boot.
There has been water in the cabinet making things there not working such as the key pad. The machine does not coin up. The on/off switch does work, although it is loose in the bottom of the cabinet. It isn't worth shipping this machine as it will likely loose many parts in transit.
The machine boots every time it gets power-on and the displays look good and the controlled lamps surprisingly work too on the playfield.
I don't hear sounds.
Buy this piece of junk of a MotorDome so I can have some space for something nicer.
Pickup is the only way to get this machine. I have changed my mindset regarding parting
this machine.
If you purchase the machine can ask for specific parts from this machine. Shipping will be around $20 for the boards and displays together depending upon the buyers location. The playfield shipping I can not estimate at this time.
Consider the board set and the displays only and you easily will have
$200 in value.
If this machine doesn't sell this go round, I will sell parts off individually including
the playfield.
