Buttons aren't mapped correctly upon first launch of game (Arpicade)
ArcadeRu
ON, Canada
My set up is an Arpicade RaspberryJamma. I'm only using this to run MK2 and MK3...that's it. I plan on using it to just run one or the other, but before I get to that step of making the system autolaunching to one of those games I want to make sure everything is running smoothly.
So this is where I'm running into issues, when I boot the system in my cabinet and choose either MK2 or MK3, it loads but the button mapping is wrong. I press P1 and it reads as P2 and and P2 is not recognized, among other issues. I can exit the game and come back to it and it works perfect.
If I launch MK2 first after booting, the button mappings are incorrect. But if I exit and go back into MK2, everything works perfectly. Then, if I launch MK3 after that, it also works fine on the first try.
However, if I boot the system and launch MK3 first, the buttons are mapped incorrectly. After exiting and relaunching MK3, the buttons are correct and MK2 also works properly on the first launch after that.
So it seems like whichever game I launch first upon booting the system the buttons are not mapped correctly upon first launch, but after exiting all the games are correct starting them back again. How do I eliminate the bug of wrong button mapping upon first launch of any game?
Update: So the solution was to update the software to the latest version and that worked, in case anyone else runs into this. dee2er was very helpful and suggested this solution!
Replied to your PM before seeing the thread...
You haven't mentioned which version of ARpiCADE you're using. But asssuming you're on ARpiCADE_5v2 the update to v2.1 should fix any hotkey order issues like this.
