LOL!
I just went to order some parts from Bob Roberts for my kit and I told him what I was planning on doing and when I mentioned that I was getting a 'ground' from the other button wiring he said the same thing I was told here earlier -- you flat out have a wiring issue somewhere in your cab.
He said that floating ground or not, the only thing that would cause the button to act as if it had been pressed was if the other wire was in fact a ground.
So crap, what to do now? I don't want to hack everything up just to find out that I had a wiring issue all along that was causing these problems!
Ken, I just checked the ground on the screw of my inactive GL board against the cabinet ground and it was definitely grounded perfectly.
I just received some jamma extension cables from jammaboards and interestingly enough when I set the DMM to 2000K ohm and touched the ground wire (pin 1) on the jamma extension harness running the (active) NBA Jam board I got a reading of about 560. Shouldn't this have been 0 or close to it?
Also interesting was that I got no reading at all from pin 28 on the jamma extender harness and I'd think that'd be at the same reading as pin 1?
Am I missing something here?
I'm gonna go move the extender harness to GL now and probe those same pins...
