burnt edge connectors
hovo
quebec, Canada
how to fix this problem
please repsond thanks
saw that on arcade reapir tips, but i think ill hve to repair it more better wayyy ...
if anyone knows, thanks again
well, ultimately, you want to replace the edge connector on the harness. that's what's causing the problem. the other thing you could do is repair the edge on the pcb. there's threads about that. finally, you could solder direct wires from the connector harness pins to the pcb, but that's a little messy.
