BurgerTime Rusted Joystick Grommet Driving Me to Virtual Veganism
Samuel-IGN
SAN FRANCISCO, California
So ready for a long weekend of scrubbing my control panel clean for a new CPO and the freaking rubber (metal-centered) grommet will NOT come off. Soaking it in WD40 right now, tried pounding it, heating it up and other caveman techniques but I am seeking more levelheaded advice.
Is this thing even supposed to slide off? Images attached of offending lever.
should come right off. Pretty sure that uses the same stick as ms pac which means the grommet is readily available. After I confirmed that I would probably cut the old grommet off at the rubber and take a pair of pliers to the metal piece that contacts the shaft. Twist until you work it off. Then replace with a new grommet after the shaft is cleaned up.
penetrene will get in but will take some time to penetrate fully.
you could try
- a steel block with a u shaped slot same diameter as joystick shaft so steel insert in the grommet sits on the edges
- put in js shaft in steel block slot upside down (ball down)
- try some "freezeit" spray to cool the shaft top and bottom as shrinkage will help to loosen the shaft, and
- tap lightly but sharply with copper headed hammer until it starts to move
- add penetrene or wd40 and redo procedure
as shaft moves into bush sleeve you may need to use a same diameter/slightly smaller hardened flat tipped pin punch to continue driving it through the bush
Don't waste your tiem with WD-40.
Use PB Blaster, its made for rust and a rust catalyst. Auto stores carrry it, probably WallMart and hardware stroes too.
I use it all the time for auto work as I'm also a mechanic.
http://blastercorporation.com/display.cfm?p=50003&pid=4
I would try twisting the grommet while holding the stick shaft though too.
I've had a couple pain-in-the-ass ones.....I just take my Dremel and cut them off.
Edward
All fantastic advice, many thanks! I'm leaning towards the rust solvent and pounding solutions for now because I do want to preserve the grommet if it's tough or impossible to find. BUT -- if it is the same as Ms. P then I definitely won't have to worry about that! Heck, I could probably buy an entire Ms. P machine for less than a rare joystick part price, I think there's a mandatory broken Ms. Pac-Man in every laundromat in San Francisco. And there are a lot of laundromats here.
The grommet on your joystick is a $10-$15 item, new.
http://www.therealbobroberts.net/joyparts.html
Half-way down the page...under Midway.
Edward
The grommet on my Pac-Man joystick was seized on too. I ended up using a gear puller and it worked well. It didn't even break the grommet so I was able to reinstall it when I was finished cleaning up all the parts.
