BurgerTime JAMMA
SteelRush
Donor 2017
Florida
I want to put an original BurgerTime PCB into my 27" JAMMA cabinet. I found a Burnin Rubber (Bump n Jump) JAMMA adapter. Will this work for BurgerTime as well?
I'd much rather find an original BurgerTime cabinet at a reasonable price but that hasn't happened yet.
There may just be one ground different on the pinout. For instance, the Burgertime/Bump 'n Jump "cabinet to JAMMA adapter" that ArcadeShop sells has a jumper to change between which cabinet you are using it with.
check arcadeshop.com for the adapter you need..
If you know the pinout of BurgerTime, you could always make your own adapter/harness, if an existing adapter is not available.
