Burgertime DECO
Jr. Pac
Donor 2012, 2015
KC Area, Kansas
I have a chance to get a free DECO non-working Burgertime in a generic cab with the alternate marquee. What is one worth?
The cassette system one? You'll probably never get it working.
It is worth very little. But free is always good.
Forget about it working.. Your not going to find parts for it. you not going to be able to fix it... Even if you do get it to load, it will not be reliable..
If someone will remake the multi deco kit, it would be cool as there are a bunch of good games on the system.. Otherwise its worth more if you convert it to something like a 60 in 1.. Burgertime is one of the games in the multigame, so its a good use..
You have not read enough Jr. Pac posts to know he is adamantly opposed to multi-jamma boards (until his opinion changes)
:p
I have ALL the parts you would need to get this machine going. They are for sale but not cheap.
The guy says he thinks it just needs a new cassette. I'm not sure if this is true.
probably needs a new fuse or two as well. and maybe one button reconnected.
tip: don't believe when the seller says "oh, it just needs X". assume the worst and hope for the best.
A common issue on that family of games is the microfusistor on the cassette assembly. Tough part to find.
Yup. I highly doubt it's the cassete. It's from the same person I'm getting my Pac/Ms. Pac from. He's not entirely sure what's wrong with it.
I'm not going to get it, then.
