metahugh Active member VAPS Joined Jun 10, 2004 Messages 6,127 Reaction score 20 Location Michigan Feb 1, 2010 #1 Are the pinouts the same for the CPU/DATA PCB? I meant to say Data East. The boardset looks almost exactly the same except for the fact that it is a little bit shorter. Last edited: Feb 1, 2010
Riptor Well-known member VAPS Joined Jul 10, 2007 Messages 12,078 Reaction score 144 Location Leonartown, Maryland Feb 1, 2010 #2 I believe the deco and midway are different pinout but not positive.
OP OP metahugh Active member VAPS Joined Jun 10, 2004 Messages 6,127 Reaction score 20 Location Michigan Feb 2, 2010 #3 I think you are right. I'm having sync issues with it.
mattosborn Well-known member VAPS Joined Aug 19, 2008 Messages 6,688 Reaction score 2,756 Location Derry, New Hampshire Feb 2, 2010 #4 metahugh said: I think you are right. I'm having sync issues with it. Click to expand... Some boards have separate H and V sync, and some have composite. You just need to wire the monitor up right. Easy fix.
OP OP metahugh Active member VAPS Joined Jun 10, 2004 Messages 6,127 Reaction score 20 Location Michigan Feb 2, 2010 #5 mattosborn said: Some boards have separate H and V sync, and some have composite. You just need to wire the monitor up right. Easy fix. Click to expand... Is this the correct pinout for the DE boardset? http://www.crazykong.com/pins/Bumpnjump.pin.txt
mattosborn Well-known member VAPS Joined Aug 19, 2008 Messages 6,688 Reaction score 2,756 Location Derry, New Hampshire Feb 2, 2010 #6 metahugh said: Is this the correct pinout for the DE boardset? http://www.crazykong.com/pins/Bumpnjump.pin.txt Click to expand... Yes, that looks correct. The Bally/Midway and DE (non-cassette) boards have the same pinout, but be careful putting the video connector on as the spacing is a bit different.
