BubbaK
I picked up a Burgertime over a year ago and I'm finally getting to restore it. I'm hoping its salvageable. It has a bit of water damage to the bottom, which I can replace the bottom piece. Don't understand why its particle board on the bottom and plywood everywhere else. My biggest concern is repairing plywood that has started to separate. I sanded the cabinet down and the front and one side are pretty messed up. I picked up some bondo. My thought was to run some glue around the edges of the plywood that was lifting and clamp it tight. Let it dry, sand then start working the bondo. I've got a few pictures..
