Two pics attached:
First is a pic of a diode that is part of the flipper coil...one leg is sheared flush with the body of the diode...can it be saved? Is there a work-around/loophole to make it work? I do not have a spare diode.
Second pic..i am installing three bumpers...there is one short leg and one long leg. I see where the short connects to and i was told the long leg simply solders to the ground wire that is laid out throughout the game....so in the pic, if i solder the leg in the pic to the ground wire you see below the leg, i will be good, correct?
