Bump and Jump Tilt?
MIKE96
miami, Florida
Hi, my Bump and Jump works fine until I switched the midway coin door with a nicer identical one, when I plugged it in it says "Tilt" on the screen and won't work but as soon as I disconnect the door its seems to work fine.
any help is much appreciated
thank you
just out of dumb curiosity, is there a slam/tilt switch inside your new coin door? it'll be a leafswitch, make sure that the contact isn't stuck touching the other half.
