building up paint thickness after Nintendo enamel strip
mc300baud
Tacoma, Washington
ok, i picked up a cheap plywood DKjr that's been all hacked up. it has a Mario Bros. marquee, Vs. smoked bezel, Popeye CPO, Mario Bros. edge connector wiring harness, etc. it's a fairly solid working cabinet that i want to use as the basis for an eventual Double DK that's themed DK.
one side of the enamel was really trashed and the previous owner peeled it all off. of course now that side is rough and needs a bunch of patching and eventually a repaint. i'd really like to build the side back up to the level of the t-molding as the enamel had a pretty decent thinkness to it that's now missing. i snagged a sample of the formica laminate that Lowe's sells and it's way too thick, and there's no way i know of that i'd ever get a layer of bondo even across the entire side.
anyone have any suggestions? is there some super-thick primer that i can put a couple of coats on with that'll do the trick? i do not have access to a compressor and will need something that either can be rolled on or sprayed out of a can.
Make sure that you are not using a laminate "sample" to judge the thinkness of the laminate you'd like to use. Formica and Wilsonart's "sample chips" that you can get from stores, the little 1"x2" rectangles, are MUCH thicker than the actuall laminate. I know this because I recently restored a 60's metal office desk and topped it with a retro styled Formica laminate. The samples were thicker than the actual laminate used, even when I'd add in the thickness of the contact cement.
Joint compound works well in situations that are too large for bondo. I just re-vinyled my Z-Back and used it to smooth out the entire sides of the cabinet.
that makes sense. maybe i'll head back over there this afternoon and look at the actual sheets of laminate.
assuming they're thin enough, are they paintable after sanding?
