taylormadelv
- Joined
- Dec 7, 2008
- Messages
- 1,840
- Reaction score
- 43
I am in the process of a very similar project and I have been watching this thread closely. I got a GT Fore! green board from a klov'er here and then I was lucky enough to score a complete World Class Bowling cabinet 2 weeks later to put it in. The power supply was critical to get the HD to spin up, only the ATX PS in the bowling cabinet would power the game up, when I tried a power switcher outside the cabinet to test, it would never work. Funny thing was that the power switch on the PS was OFF when the WC bowling was in it, I had to turn the PS switch ON.You don't need an adapter. There is a VGA cable that runs from the 3dfx card to the gt board. Just take it off the GT board and plug your monitor cable directly into it. You may need a gender changer. I believe you also have to change the dip switches on the board to go to hires mode.
I was under the impression that GT Fore! only outputs med and low video resolutions, not a VGA type signal. I may transfer all the GT guts to another cabinet but that cab has a VGA monitor in it and I was expecting to have to run a converter to get the picture to display on a true VGA monitor. I saw your post and now I am curious if I can actually get away with running this directly to a VGA monitor..........
Once you play GT with a Missile Command 4.5" trackball, you will not want to go back, it's just very involved to play a non-mame version of GT with a MC trackball but it might be worth it.
