Ditto!Does Quatum need a steeper effect for game play? Or is the second speakier just for MOAR PAWR?
If stereo is not important I'd consider just combining the 2 channels before they go to the power amp and use the single speaker.
I built my Crystal Castles cabaret with two speakers, but I had to make a custom kick plate to make it work.Ditto!
I've seen two smaller speakers mounted where one was originally, but the owner made an adapter plate, so the mounting worked. I'm sure somebody could 3D print it, or you make it from wood.
Scott C.
On thing to consider, using two 5×8 speakers turned horizontally, rather than one 6x9 vertically. This would allow the majority of the sound to exit the original speaker grill.I'd like to leave the kick plate original and don't know how to design stuff to be 3d printed. I'll try to make something out of wood. You'll never see it anyway.
Confirmed I had the x/y wires goofed. I swapped them and it looks like we are good to go. Just need to find a cabinet now.
Hey man, I'm just giving you options and examples. Pretty easy to pop those old kick plates off. Running two speakers pretty much in the exact same spot isn't gonna sound quite right. They need to be spread out a little bit for any real impact.I'd like to leave the kick plate original and don't know how to design stuff to be 3d printed. I'll try to make something out of wood. You'll never see it anyway.
sweet!!I finally finished putting everything together. Just waiting on art.
Does anyone know of a good source online to get a dark piece of tempered glass to use? "One day glass" looks legit but I'm just not sure how the color/tint will be compared to OEM. I think graylite 14 is preferred but no longer available?
I used one day glass. It was $150 shipped and took less than two weeks. It might be just a hair darker than OEM but is perfectly fine IMO.I'm convinced the key to getting front glass is finding a good small town glass shop. The shop in my rural south Alabama hometown will cut Greylite pieces for me at a half to a third of the quotes I get in metro Atlanta.
Can you provide the dimensions and model of glass you got from them? I have a repro Centipede cabaret cab that I want to make a Quantum.I used one day glass. It was $150 shipped and took less than two weeks. It might be just a hair darker than OEM but is perfectly fine IMO.
It was the 'dark gray' but I don't have the dimensions handy. It was whatever the OEM size is.Can you provide the dimensions and model of glass you got from them? I have a repro Centipede cabaret cab that I want to make a Quantum.
Thanks.
