BugTrap logic comparator repair
parism
Donor 10 years: 2014-2015, 2017-2021, 2023-2025
Villanova, Pennsylvania
The BugTrap has developed an issue where upon inserting an IC led 6 comes on
I quickly tested the 2N5061 thyristor, switch and associated capacitor for the LED pin in circuit and all appeared good. I did find two resistors out of spec;
These should be measuring about 850 (lower) and about 1k (higher). Instead they measured 340 and 170 respectively. However, both were correct spec out of circuit.
I took the 2n5061 out and it passed, I then checked the associated LS86 and found two pins floating, pin 11 and 13.
Bad out of circuit
Replaced and we are good to go, no more led lighting upon IC insertion.
Pro tip: remove the top of the ZIF to put the case back together (or take off the case)
Case back together
p
